Seafire XV
I just completed the Nautilus upgrade that uses fsvt rotors up front and csvt fronts in the back. I was very happy with the quality of the Nautilus brackets, but a bit disapointed with their instructions. They were good enough, but it would have been nice to have had more photos at each stage of the conversion. Especially regarding the mods to the stock rear brackets. For anyone planning to do this conversion, the fronts are quite easy, just drill the bracket holes on the stock hub and grind away on the upper ear and you are set to go. For the rear brakes, there is more work since you must do alot of grinding on those rear brackets to gain the needed clearance. You will need to do the most grinding on the side of the bracket that will face the inner side of the rotor, especially toward the top. I tried to remove enough material so that I would'nt have to turn the rotors as suggested in the instructions, but no matter how much I workedat it I could'nt seem to get enough. I gave up and had .015 removed from both sides and that did it. Also, instead of grinding away on the inner hat suface, I brought the rear rotors to my local machine shop and had them turned down a total of .020 and that let them sag nice and loose. The brakes feel very good, a bit stronger than stock, which is what I Expected, and the
bigger rotors look nice. I went with EBC red pads to see if they dust less than the carbon metallic Mintex
pads that I had previously. One thing to watch out for with the EBC pads, it seems that you will get the
early caliper pads if you order them for a 98 or 99, so if you have a late 98 or 99 with the later style
calipers, just order pads for a 2000 CSVT and you won't have to let you car sit for a week like I did
while I waited for the correct pads!
