power antenna:drool: new to me from a u-pull yard tour and cheap to the wire to install cost more than the antenna plus standing on my head doing the wiring under the dash was a treat :dizzy: and it worked the first time :shocked:
How did you get yours to stay down when you're not using the radio?
Mine has that same wire but just like the stock radio any time the unit is on the antenna comes up.
Get a new deck
like I said the hardest part was standing on my head under the dash:dizzy: you do know that there is a nut on top and two at the bottom ?Did you have a hard time getting it off? I want to do this with mine, but the damned un powered one on the Contour seems like it is glued on!
the mast should defualt to the down position when the radio is off but it stay's up when using the cd player [stock] I'am thinking of using an on/off switchHow did you get yours to stay down when you're not using the radio?
that would be cool also just not in the funds ,using a hocus pocus unit ?Get a new deck
I want to remove my power antenna and have that hole filled
MY WIFE'S WINDSTAR HAS THE ANTENNA BUILT IN THE RIGHT REAR SIDE WINDOW . I WONDER ,IS THERE AN AFTERMARKET KIT FOR THIS :shrug:ya , i hate antennas. i think my grand prix's antenna is built in the glass for the rear windshield.i cud be wrong. but i like that idea
unscrew the piece that has the four slots .maybe not the tool for the job but I very carfully used a flat srew driver and a hammer:shrug:It's the top piece that is giving me the problems.
P B Blasteryeah I Used The Same, But The Damned Thing Won't Budge.
