AGrayson84
Hi everyone. I have a '98 E0 CSVT that I picked up back in September. The temperature mixture control was something that wasn't already worked. I'd either get really cold air, or really hot air, nothing in between. Someone suggested that I replace the blend door controller. I got a used on in the mail recently and after removing my original one, I notice that something. With the temperature controller all the way to the let (coldest position) the little "nub" that rotates to control the blend door would go all the way to one end. I started slowly rotating the temperature dial to the right (warmer) and the nub didn't budge until about 5 clicks away from the coldest point when the nub rotating all the way in the other direction. There was no in-between. I figured that was the problem.
I plugged the replacement blend door controller in and did the same test. This time, I about 3 clicks from the coldest setting the nub rotating roughly the same amount of distance. One more click to the right, and the numb rotated all the way to the other direction. I decided I'd still try to install it, but I'm still not getting full control of the temperature. It's either too cold, or too hot, even with the extra position that I now gained with the replacement blend door controller.
I'm also noticing that at least when I'm using heat, I'm getting hot air out of the dash vents when the middle dial is set to Floor only. Not much air... I don't feel it hitting my face, but if I put my hand near the vent I can feel it the heat. Is this normal for these cars, or do I maybe need to replace my in-dash heat / AC controls?? Thanks!!
-Andrew
-Andrew
