We don't have the clutch safety switch. The PCM is wired directly to the starter relay, not over clutch switch.
We have only the red 4-pin clutch switch. 2 pins are for cruise control and 2 pins of this switch are for the pcm (the switch in the middle of the attached PDF). That's the one where my problem is (trouble code P0704). On the pin 64 I've the +5V. I found a second SFG2 PCM ... should be here in some days ... I try it and we'll see.
When it works, I'll need your help and a nice tune!
By the way, are all my trouble codes and my engine setup:
Codes:
-P1451: EVAP-Valve failure (we don't have this one)
-P0453: failure in "fuel vapours catching system" (should be caused by P1451)
-P1409: EVR-Valve failure (removed EGR completely, incl. EVR-Valve)
-P1401: DPFE-Sensor failure (removed)
-P0141: HO2SHTR12 failure (we don't have this)
-P0161: HO2SHTR22 failure (we don't have this)
-PXXXX: no IMRC connected, and no trouble code ... WOW!!!
Engine setup:
-ST220 engine
-10.8:1 compression ratio
-ported heads, valve seats moved to the outside and set to minimum
-ST200 (CSVT) cams
-MSDS headers
-BAT Y-Pipe with high flow CAT
-Mongoose exhaust for ST200
-ST220 intake (all intake parts match, no steps between the parts)
-ST220 injectors
-65mm optimized throttle body
-stock MAF
-stock airbox with K&N drop in filter
-ST200 knock sensor
-adjustable fuel pressure regulator
-one Innovate Motorsports LC-1 on each side, simulating stock lambdas (actually programmed to work at lamda 0.94) ... would be nice to switch off the check for lambda heater (than I can remove the dummy lambda sensors)
-95 octane fuel (98 / 100 octane is to expensive for me)
... for this little changes I need a tune! :laugh:
