Info On How To Bypass The Factory Amp In My Svt Needed
00SVTGA
Gwinnett , Ga
hello all-
i need to bypass the factory amp because as it stands now it sounds crappy on my alpine 9855. i had a system installed before but i'm to lazy to re wire everything back throught the doors to run external amps after i removed them. i've heard there is a wiring harnees that can bypass the factory amp that would be pretty much plug and play is this correct ?
if so whats the manufacturer part #
how much hard wiring to the speaker wires is needed if not. i tryed to search but i hate the way this new site is setup. so if some one would help me out with a quick DIY that would be great.
thanks
That Crutchfield one lets you connect your HU right to the speaker plug, I got one like that, just shorter than 18 feet.
