Few things mentioned need to be fixed
Of course none of this really matters with projectors as you get the color from the shield.
Low beam projectors are supposed to stay on when the contour high beams come on. There will be no power drained away from a properly wired HID system. Which will pull its power straight from the battery, and thus will pull a constant voltage which the ballasts will regulate down for the bulbs.Question: What about using HIDs with DRLs?
Answer:
If low beams turn off when high beams turn on, this will reduce bulb life and damage your ballast. HIDs need a constant, steady stream of power. Even if low beams stay on with high beams, your are drawing power away from the HIDs.
Pretty much the same thing as before, DRLs dont pull power from a properly wired system. Ask Goonz, he has DRLs.Question: What about using HIDs with DRLs?
Answer:
DRLs have been known to cause problems with HIDs when they activate. HIDs need a constant, steady stream of power. When DRLs activate, they draw power away. This reduces bulb life and damages the ballast.
3000k is yellow, 4100-4300 pure white, 5000k blueish tint.Q: So, what "k" kit do I need??
Answer:
It is personal preference. If you are serious about your light output and want the best light output, go with a 4100k - 5000k kit. If you want a slightly yellow look - 4100k. If you want a pure white look - 5000k. The higher the k, the more blue to purple it gets - but the tradeoff is less light.
Should specify between a kit that needs to be used in a reflector housing (rebased kit :nonono and a projector set up. Projector set ups are actually really easy to build. Just need two identical ballasts, and the know how to wire them up (which can be found from the automotive lighting FAQ)Q: Can I create my own HID kit?
Answer:
Yes, but it's not recommended because not all HID components by various manufacturers fit each other. You have to know what works with what before you create your own kit. If you want to create your own custom kit like GoonzSVT, do the research to understand what it takes.
