DocStruthers
- Joined
- Dec 11, 2008
- Messages
- 864
I figured traction would improve slightly (not saying fix the wheel hop or all the issues of a front wheel drive) only traction bars will do that for us (when Mike and Josh get versions out)....but I mean they will benefit from less bushin deflection by having heims....the stock control arms having rubber bushings for dampening vibrations and make for a smooth ride...well these arms will provide a more solid bushing (heim) to deflect less....therefore helping aid in traction. Correct me if I am not thinking clearly on all that.
Very correct, only thing flexing then will be the sub frame, if the power is there to do so.
At the same time if you guys with stock cars enjoy your comfortable Contour, these arms may make the ride harsher, not by a lot but keep in mind lower profile tires, performance springs and struts with solid mount control arms. . .
