trhlz1222
heres my other thread i had. i cant seem to figure out whats causeing the headlights not to work. ive check all the fuses, all the relays(not clicking). i put the horn relay in both high beams and low beams and it does nothing and i also checked to see if the headlight relays would work in the horn and the horn still worked. bulbs are not blown either. parking lamps and fog lamps turn on fine and signal lights work fine.
http://contour.org/ceg-vb/showthread.php?t=46979
