How to remove/install window motors?? 98 Mystique
Very easy...there might even be a Youtube vid for it. Remove door panel. Peel back water-proof layer. The motor/frame is attached to the window via two clamps that the window "sits" in. Loosen them then show window up into door frame. The motor/frame is attached to the door panel with 4 bolts. loosen then pull motor/frame through access panel in door. Install the new one in reverse order. You'll have to lower the window carefully by hand and position it into the aforementioned clamps. You may have to adjust those a little to make sure the window goes all the way up.
Oh wow, so you have to remove the regulator out to get and remove the motor from it then, huh? Do you have to remove the glass window or not?
Thanks for your reply and help!!!
Anthony
P.S. I checked on youtube, didnt find anything...
