This should sum up exactly how the Zetec valve, tappets, and noise associate:
It is necessary for a clearance to exist between the tip of each valve stem and the valve operating mechanism, to allow for the expansion of the various components as the engine reaches normal operating temperature.
On most older engine designs, this meant that the valve clearances (also known as tappet clearances) had to be checked and adjusted regularly. If the learances were allowed to be too slack, the engine would be very noisy, its power output would suffer, and its fuel consumption would increase. If the clearances were allowed to be too tight, the engines power output would be reduced, and the valves and their seats could be severely damaged.
The Zetec engine employs hydraulic tappets which use the lubricating systems oil pressure to automatically take up the clearance between each camshaft lobe and its respective valve stem. Therefore, there is no need for regular checking and adjustment of the valve clearances, but it is essential that only good-quality oil of the recommended viscosity and specification is used in the engine, and that this oil is always changed at the recommended intervals. If this advice is not followed, the oilways and tappets may become clogged with particles of dirt, or deposits of burnt (inferior) engine oil, so that the system cannot work properly; ultimately, one or more of the tappets may fail, and expensive repairs may be required.
On starting the engine from cold, there will be a slight delay while full oil pressure builds up in all parts of the engine, especially in the tappets; the valve components, therefore, may well rattle for about 10 seconds or so, and then quieten. This is a normal state of affairs, and is nothing to worry about, provided that all tappets quieten quickly and stay quiet.
After the vehicle has been standing for several days, the valve components may rattle for longer than usual, as nearly all the oil will have drained away from the engines top-end components and bearing surfaces. While this is only to be expected, care must be taken not to damage the engine under these circumstances - avoid high speed running until all the tappets are refilled with oil and operating normally. With the vehicle stationary, hold the engine at no more than a fast idle speed (maximum 2000 to 2500 rpm) for 10 to 15 seconds, or until the noise ceases. Do not run the engine at more than 3000 rpm until the tappets are fully recharged with oil and the noise has ceased.
If the valve components are thought to be noisy, or if a light rattle persists from the top end after the engine has warmed up to normal operating temperature, take the vehicle to a Ford dealer for expert advice. Depending on the mileage covered and the usage to which each vehicle has been put, some vehicles may be noisier than others; only a good mechanic experienced in these engines can tell if the noise level is typical for the vehicles mileage, or if a genuine fault exists. If any tappets operation is faulty, it must be renewed.
