Below is information from the 1996 Ford CD. Not sure how close it is for the 2000. You should get a hold of todras (a CEGer) and purchase a 2000 Ford CD (about $8.50). Hope it works out well.
Brake Drum
Removal
1. Raise vehicle on hoist.
2. Remove wheel and tire assembly.
3. Remove drum retainers.
4. Release rear brake strut and quadrant by removing plug in brake drum and inserting screwdriver into rear brake strut and quadrant. A forward motion of the screwdriver will separate the quadrant from the knurled wheel and allow brake shoes to retract.
5. Remove brake drum.
Installation
1. Position brake drum on rear hub.
2. Install drum retainers.
3. Install wheel and tire assembly. Tighten lug nuts to 85 N-m (62 lb-ft).
4. Lower vehicle.
Brake Shoes and Lining
Removal
1. Remove brake drum as outlined.
2. Remove brake shoe hold down springs and brake shoe hold down spring pins.
3. Remove brake shoe retracting springs.
4. Remove brake shoes and linings. Remove parking brake return spring. Disengage rear brake strut and quadrant from rear brake shoe and lining.
5. Remove parking brake rear cable and conduit from parking brake cable anchor on trailing brake shoe.
Installation
1. Lubricate rear brake shoe and lining contact points on back plate with Silicone Dielectric Compound D7AZ-19A331-A or equivalent meeting Ford specification ESE-M1C171-A.
2. Engage parking brake rear cable and conduit into parking brake cable anchor on trailing brake shoe.
3. Position trailing rear brake shoes and linings on rear brake backing plate. Engage rear brake strut and quadrant. Install parking brake return spring.
4. Install brake shoe hold down spring pin and brake shoe hold down spring.
5. Insert leading rear brake shoe and lining into slot on rear brake strut and quadrant. Install brake shoe hold down spring pin and brake shoe hold down spring.
6. Install brake shoe retracting springs.
7. Adjust rear brake shoe and lining by first measuring brake drum with Brake Adjustment Gauge D81L-1103-A or equivalent.
8. Insert a small screwdriver into the knurled quadrant of the rear brake strut and quadrant to release brake shoes. Adjust the rear brake shoes and linings to the same measurement of the brake drum by expanding rear brake strut and quadrant.
Wheel Cylinder
Removal
2. Remove rear brake shoes and linings as outlined.
3. Disconnect rear wheel brake hose from rear wheel cylinder.
4. Remove rear wheel cylinder bolts and rear wheel cylinder.
Installation
1. Position rear wheel cylinder onto rear brake backing plate and install two rear wheel cylinder retaining bolts. Tighten bolts to 10-13 N-m (7-9 lb-ft).
2. Connect rear wheel brake hose to rear wheel cylinder. Tighten fitting to 14-24 N-m (10-17 lb-ft).
3. Install rear brake shoe and lining as outlined.
4. Bleed brake system.
