B BrianKemp CEG'er Joined Jul 21, 2008 Messages 61 Location Decatur, Al Jul 13, 2012 #1 I'm Buying an 07 Milan 3.0 and wondering if this is the same engine as the Taurus 3.0.
R RFcsvt Veteran CEG'er Joined Dec 7, 2004 Messages 663 Location Hammond WI Jul 13, 2012 #2 I believe the engine in the Milan for that year uses VVT which would make it different than the typical engines used in 3.0 swaps. So basically no, I don't think it's the same as the Taurus engine.
E elraido I kant speel Joined Oct 28, 2004 Messages 15,657 Location Northern MN Jul 13, 2012 #3 Nope. Won't work....unless you like a lot of custom work. Then go crazy
B Blackcoog Hard-core CEG'er Joined Nov 14, 2000 Messages 1,998 Location Mounds View, MN, USA Jul 16, 2012 #4 BrianKemp said: I'm Buying an 07 Milan 3.0 and wondering if this is the same engine as the Taurus 3.0. Click to expand... Block is the same. As mentioned the heads are different due to VVT and is not compatible with the Contour/Cougar.
