Any chance you found those pics morbid? How hard is it to hook up the lines? This seems like a pretty simple and good improvement.
Sorry... work is killing me and I totally spaced out this thread.  If you're just doing the p/s cooler, you can use the radiator ties to hold it on (it's not that heavy).  Mine is the 2" x 2" x 8-1/4" Earls (pn:
20706ERL)... the smallest they make.  That model comes with the fittings for -6AN hose.... -6 hose fits the p/s lines.  I used Earls Perform-O-Flex -6 hose (
406006ERL) with Earls 90* 6AN fitting (
809106ERL) for the right and 120* 6AN fitting (
812006ERL) for the left, with two Econ-O-Fit -6 clamps (
900106ERL) for the p/s lines.  To hold the lines (and make it look nice), I used a pair of their -6 hose separators (
167209ERL).  That way was not exactly cheap and ended up running around $180 for everything (steel braided hoses, AN fittings, etc).  It would be much cheaper with rubber hoses and push-on fittings (probably around $70-80).  Either way... that tiny (2x2x8-1/4) cooler is theoretically more than 2x effective than the OEM p/s cooler.
For mine, I have an aluminum plate that I made into a shelf.  It's about 24"w x 4"d x 3/8"h and I replaced the bracket under the condenser with it.  I have the p/s cooler on the left and the oil cooler (
81910ERL) on the right, and together they're about the same width as the condenser.  I also made some brackets to attach the front shelf corners to the frame... but I need to add one to the center as it's starting to bow.
I'm about to redo all of my engine oil lines (again)... I'll be sure to take pics when I'm done with that.
