TheMexicanJob
Banned?
did you pull these out of your accord before you sold it? if so then that is a little strange unless the accords wiring is switched from ours
I doubt it because accords have never come with HID's from the factory.
The regular halogens work though so it cant be blown fuses rightIm with Goonz, check your fuses.
Fuse blow I guess the bright lights still woork but its not the underhood fuses, were shoud I looki told you so.
what you need to do is take the wires out of the connector that plugs into your original harness and switch them. just take a pin or a jewlers flatblade screwdriver and pry back the little tab inside the plug while pulling on the wire. if you need pics i will go get some for you of mine.
Yeah but it was 8 oclock and getting dark fast and Im at school so I dont have a garage with light, I fooled around with what you said for 6 minutes and I couldnt get em out so I did the next best thing, worked out either wayi told you how to pull out the pins from the connector.:shrug:
So What do I do? get a relay harness? Wher from, I thought the fuses blew because it taks more to fire em up that regular halogens, Im pretty sure I read other ppl upgrading fuses too, so I thought it was safe
