dn9979
I have a 98 contour svt that i just picked up again
133k on it
If you drive the car easy.meaning no higher then 3500 to 4k in each gear car drives great and still gets good mileage
Now once i want to get on it it seems to cut out a little till it gets high enough rpms then its fine.
If i was in 5th on the freeway and wanted to down shift the car would bog down a bit,like a surge or miss.Will do this in all gears if your rpms arent high enough
the car also does this when your idleing and decide you want to rev the car up wot,but if you do it slowly it wont
i have no cel light on,changed the air filter and plugs all looked great.No engine noise or anything weird
133k on it
