xtascox
as long as the starter is connected, it will turn over.
Alright. Well hopefully I can install the new one today but time is going to be an issue. I probably won't get it in until tomorrow.
i have been having 'tour issues too.
mine died on road to work a couple a months ago.
towed it back. thought what the hell, changed UIM/LIM gaskets cleaned everything super clean, replaced fuel filter, plugs, egr gasket, and said screw it (car sounded like yours) and bought a new starter. also CEL light stayed constantly on even when reset (by fuse and negative batt cable removed) -- scanned but found no codes whatsoever! also did oil in plug area for compression and other tests CEG'rs mentioned. no start.
put it new starter and now after the new starter install it has life but won't start. i tried to avoid it but gave in and took to mechanic who just called me 1/2 hour ago and told me the front cam isn't turning and will give me further diagnosis later this afternoon.
i will post after he calls me back. >=\
got thinking and thought - maybe camshaft/cranskhaft sensor??
seeing i had oil leak too maybe leaked on to it. i did clean them but didn't think bout testing/changing them ???
Is the whole engine included in that quote?
