SvtFanatic
I hope someone can help me. Heres the story I own a 99 SVTC with 117k it runs and drives perfect. When I bought the car it had a Clifford Alarm and it worked perfect. Well after a few months the car didnt start on intial turnover. What you had to do was put the key in Auxillary and wait for the windshield wipers to go twice and the heat to turn on then the car will run with no problem. So, my mechanic took out the Clifford and installed the original keyless entry keyfob and it worked perfect for about 2 months. Now, its back to it again but it takes even longer for the car to start in auxillary because its cold. You put the key in Auxillary with the radio playing and wait for the windhsield wipers to go twice and then the car will turn on and runs perfect. This now is taking up to 40 minutes? Can anyone help is there any way to disconnect the PATS system or bypass it? I can explain the problem better if someone could Call me ASAP 425 329 9119
Greg
Thank you so much!!!
Greg
