jlm98silversvt
My stock brakes on my 98 SVT could be better. I want the Baer brakes, but will the FSVT brakes be enough since the stock braking power is not that good or should I spend the extra money and get the Baers.
I have both. Use the FSVT for the winter. Hands down the Baers if you can swing it. The extra piston's clamping force is very nice.
Personally I went w the Baers!!!! ***TIME TO WHORE***
Big jump in money tho! Depends if your keeping your car stock. Not tracking or running the car aggressively then find a better rotor/pad combo or move on to the FSVT Brake Setup!
If you want a sexy time? Go with the Baers and if you have a 94 Cobra then the pads will be interchangable just in case one of them goes down.
- amyn
What pads are you using on for the FSVT's?
No they are going on sometime in the end of Jan or Feb.Did you install your brake kit yet
Same as my Baers. Bendix Ti's.
Just bought the FSVT brake kit. How good are the pads that come with it. Should I change them for Hawks pads
amyn,were did you get the baer setup? theres pretty much no online contour stores anymore that sell aftermarket parts.
