AGrayson84
Hi everyone. So I picked up this Contour back in August and today marks the 2nd blistering cold morning we've had here in Maryland/Virginia and it marks the second time my CSVT hasn't wanted to fire up.
Last time this happened, I ended up assuming it was because of the cold weather. I pushed the car into the heated garage, and after a few hours it still wouldn't start. The next day, it still wouldn't start. I finally tried starting the car with the throttle to the floor and after 15 seconds of cranking it started to come to life. I got it fired up again and haven't had the problem since then (over a month ago) until today. This morning it was 7 degree in Annapolis, MD and the car wouldn't fire up. It turned noticeably slower than usual, but should have been plenty enough for it to fire up. Then my bendix got stock half-way out and was only enough to grind the flywheel slightly. I got home from work around 5:30 PM today and the bendix freed up and is working again now that it was slightly warmer, but the car still turns and won't fire up. This time holding the pedal to the floor and then letting off it after 15 seconds got it running for a split second, and no matter what position I put the pedal in I can't get the car to fire back up and run.
The fuel pump is priming, there's fuel pressure at the fuel rail, and there's a fresh fuel filter in the system. Last time this happened, the car had fuel pressure and the pump was priming, and I put a spark tester between all 3 front spark plugs and coils and it was getting spark just fine. I'm not able to check for spark this time, but I'm thinking that hasn't changed.
The car has a chip in it with a tune to turn off the CEL for the EGR codes (EGR was removed on this car) and for DPFE codes. I've removed the chip on this most recent incident as well as the first incident and the chip/tune seems to have no effect on this issue.
Here is a video of what the engine was sounding like the first time this happened, before I pulled the car into the garage:
Here is a video of me cranking the car over for the 20th time the following day, in a heated garage, after re-wrapping the wiring that runs from the positive terminal on the battery to the underside of the fuse box that sits beside the battery. During this video, the car happened to finally start and I hadn't had the problem again until today:
And lastly, here is a video from the inside of the car from tonight, doing the same thing it was doing in the first two videos:
Any ideas what might be preventing the car from firing up???? Thanks!!!
-Andrew
-Andrew
