avengerc4
I was driving along on the highway around 75 and all of a sudden I lost speed...then got some back...then lost...went to the side of the road and stopped after I was through the onramp...this is what happened
The half shaft seal broke. Where do I get a new one and how do I put it together? I hope no damage is done to the trans. Should I also get a new trans seal? It looks fine. Would I need a new axle you think?
What would cause this to happen? I know when I tried to push the 1/2 shaft back into the trans nothing but the engine moved. I could literally shift the motor. It seemed the lower trans mount that I just changed out to the poly filled was moving back and forth. Also that bolt was perfectly in the center of the hole and is now not. What should I do? I need to pay 25 bucks a day for a rental. I need this fixed.
If I can't get these new I saw a used MTX 75 in the junkyard not an SVT though would they swap?
Thanks!
Thanks!
