SilverSVTC
Ok guys... Before somebody says search! I've been, for the past week. Read about changing wires & plugs, fuel filter, clean maf sensor... I've done it all! Only other fix I've read was fuel pump! Can a bad fuel pump cause this while running flawless in the upper RPM's? Problem I'm having is, car hesitates/misfires from 1st through 3rd and after hitting 4rth... runs perfect! Also when I turn on AC... even worse! What's going on? Recently picked the car up as my daily driver and all of a sudden this started happening. Your help will be much appreciated
