I just bought a set of Optilux 2500 driving lights, which have built in angel eyes. The harness is great and all, but since I am replacing the factory fogs I need to modify the harness some.
I want the angel eyes to come on with running lights and the bulbs with the factory fog switch. The supplied harness is as follows-
Angel eye leds are wired directly into the switch (female spade plug/yellow wire). Power is supplied through the switch.
Driving lights are run through a relay. The power wire goes into a 15a fuse, then the relay, and continues into the switch I mentioned earlier. When the power wire (red) and relay wire (white) are crossed, the relay connects and power is sent to the lights.
I need to find a place where power is only supplied once running lights are on, and is 12v. The relay for the lights should not be a problem to connect.
