So just picked up a project car, the heater works on every setting but high and only blows from the defrost setting oddly. I replaced the resistor and that didn't solve the high setting not working, I have three resistors I picked up along the way and none of them solved the issue. I have a contour hvac panel (the car is a 98 Mystique) that I'm going to plug in and test, doesn't fit but the connections should be the same if I'm not mistaken. Any one encounter this problem before?
