Vigilante
I'm having a hard time finding a "good" brake job how to/tutorial. All of the ones that I have found are pretty bad so far. Does anyone know of a good one?
yea don't use loctite on the brakes.
you are going to want to use brake lube for the slide pins, where the back of the pad touches the caliper. basically where metal contacts metal. this helps dampen noise. just no grease on the pad surface or rotor. its also a good idea to use anti-seize lube on the back of the rotor hat, where it contacts the hub. this helps prevent rust from freezing the rotor to the hub. making for easy removal.
