Forgive my ignorance! You do not need to remove the glove box to get to the connector to program the remotes. This is underneath the glove box. Easy to get to without removing the glove box!
To program remotes:
[FONT="][/FONT]
Turn the ignition to on position (not started)
Behind the glove box, there is a white connector. Jump the 2 pins on this connector
The horn will honk
Press 1 button on each remote you wish to program. (note - Even if you have a remote already programmed you need to reprogram this one also)
The horn will honk each time it recognizes a remote. (if the horn doesn't honk, your remote has not been programmed)
When finished programming all the remotes. Turn the ignition off
Remove the paper clip.
The horn will honk once again, completing the programming cycle
