contour_r_us
Not to split hairs or start a shooting war or anything, but any suspension where the spring is coaxial to the strut or shock axis is considered a 'coilover'.
There are plenty of suspensions out there where the spring and strut or shock don't share the same axis, much less location, so if we were to convert one of those to a coaxial spring and strut, we'd be doing a "coilover conversion". I did this to my Fox Mustang chassis: Springs and struts/shocks were widely separated from the factory, now they're coaxial on custom built double adjustable Konis. There are tremendous advantages to doing this on some cars, as it allows one to achieve much higher "wheel rates" with smaller, lighter and surprisingly lower rate springs because the spring is now very near to where the wheel and spring perch motion ratios are 1:1.
The suspension performance aftermarket has, in my opinion, co-opted the term 'coilover' to loosely define a conversion from large diameter factory springs to 2.5" I.D. race springs and adjustable spring perches, Hell, even I use this terminology.
Semantics aside, the advantage to a "race spring conversion" is a far greater assortment of spring rates and free lengths, usually 25 or 50 pound/inch rate increments and 1 or 2" free-length increments. This allows one to tune the suspension and ride height to do what one wants, instead of having to settle for what Ford, Eibach, H&R, or someone else thinks is "right".
AMEN to the above quoted post. Here is what MadDog originally stated, resulting in the "education process". It was a simple statement, inline with the above - I am slowly beginning to understand. If I read correctly, a coilover is a combination strut/spring that allows for an adjustable drop ?
Is there a good exploded parts diagram for the suspension ? I am trying to visualize some of the parts.
thanks,
Mad Dog
Thank you gmorrell for your well written explanation - Bill
