striker2
Official CEG Vendor
These are beefed up front and rear sway bar endlinks. The fronts are adjustable from ~1/2” shorter to ~1/2” longer than stock. This will allow you to keep the sway bar closer to the proper position when lowering the car. It would also allow you to adjust the preload of the bar one way or another to fine tune the handling of the car, mostly turn-in. The increased strength of these endlinks also means they won’t break or bend. The ends are 3 piece precision rod ends with a self lubricating Teflon Kevlar race.
After I installed the fronts I noticed a great improvement in turn-in in both directions, even with them set to equal lengths (how they should be installed initially). The lack of slop in the joints means the sway bar can act faster, which gets the improved turn-in.
The rears are a good upgrade from the cheap stock units and replaces the cheap rubber bushings with poly bushings. While they are technically adjustable, the shortest/minimum setting is where they need to be. With these installed, along with the fronts, the car feels much more balanced and stable in the corners.
Pictures of the fronts:
Cell phone pics of one installed
Rears:
Unfortunately I don’t have any pics of the rears installed at this time. If I get a chance this week I will try to get a pic or two of them with the car on the ground.
Pricing is as follows:
All prices are plus shipping
1 pair of Front endlinks: $80
1 pair of rear endlinks: $55
1 full set (pair fronts + pair rears): $125
Shipping:
Shipping will be via USPS flat rate shipping.
Fronts or a full set will be: $10.35
Rears will be: $4.95
Multiple sets or not in the U.S.: PM me before ordering.
Payment:
PAYPAL ONLY. I have already calculated paypal fees into these prices so there is no need to add it.
Paypal address is: danielschottler at att dot net
When you send payment please include your screen name, real name, shipping info, and what forum your from (CEG/NECO).
Time frame:
I will be making and shipping these over my spring break, March 14th – 21st. As such, all money / orders must be sent by March 11th so I can order the necessary parts.
If you would like a set please add your name to the list with what you want. Once payment is received I will mark you as paid. There is no minimum number required.
Endlinks
1. Chas (full set) CEG PAID
2. KyleQ (full set) CEG PAID
3. brapple (full set) CEG PAID
4. backseatofacontour (full set) CEG
5. kevxr2002 (full set) NECO PAID
6. jaged (full set) NECO PAID
7. isisfreak (full set?) NECO PAID
8. Gorman (full set) NECO PAID
9. rollinstylee (full set) CEG PAID
10. S.BOOGIE2468 (full set) NECO PAID
11. muntus (full set) CEG PAID
12. SVT Loki (Full) CEG
13. spider1178 (full set) NECO PAID
14. morbid (front) CEG PAID
15. 99cougarsupreme (full set) NECO
16. Linkman (Full set) NECO (and CEG) PAID
17. TeamSVTour (full set) CEG PAID
18. 111R (fronts) CEG PAID
19. TOPIK(FULL SET) NECO
20. Desertneco (Full Set) NECO
21. Monkeygrits (Full Set) NECO PAID
22. tigerbalm (full set) CEG PAID
23. Wien_Sean (full set) CEG PAID
24. Arnold (full set) CEG
25. Redlineracer12 (full set) CEG PAID
26. sonza68 (fronts) NECO PAID
27. kpeeks (full set) NECO PAID
28. Newcat016(Full Set) NECO PAID
29. blustreak (fullset) NECO PAID
30. SVTJON87 (Rear only) CEG PAID
31. Gooserex (full set) CEG PAID
32. 5559 (rear only) CEG PAID
33. Chromed CoUgaR (Full Set) NECO PAID'
34. Blind829 (Full Set) CEG PAID
35. CRZYDRVR (Full Set) CEG PAID
36. DevanMC (full set) CEG PAID
Rears:
Shipping:
Payment:
Time frame:
Endlinks
