Gasket for Headers ?
SVT3Rivieres
Trois-Rivieres, Quebec
Somebody can tell me how many and which gasket and hardware i need to install MSDS header and Y-pipe ?
i searched for the list but coudnt find, if you have the parts number its even better
one gasket for each manifold.
either ford or felpro
there are 6 studs and 6 nuts per manifold. can be had from Ford also.
Some people reuse their manifold gaskets. They are cheap though so to each his own.
You could also try remflex gaskets if you are concerned about exhaust leaks. I have used them and they worked very well. About 3x more expensive than the OEM ones though. I only used them when I installed headers with the engine still in the car and I was worried about being able to torque all bolts properly. When I assemble a motor on a stand I reuse gaskets if in good shape.
I do not reuse the studs or bolts. I buy and use allen bolts. Much easier to install and remove in my opinion. I have the exact size written down at home and I can get the info if needed. Be sure to use anti-sieze on the threads of whatever fastener you choose though. You will be very happy you did should you ever have to take this apart again.
I also suggest using a lock washer on the allen bolts (if you go that route).
