722hp...
Engine
2l 16v Quad Cam Ej20 Engine
Closed-Deck Subaru Block
Wrc R-Profile High Wrap Cam Belt System
Modified Oil Pump
Wrc S10 Inlet Manifold, Eight Injector Kit
72 Mm Throttle Body
5.5-Liter Alloy Sump
Oil Catch Tank And Breather System
Subaru S202 Oil Cooler
Goodrich Braided Vacuum Hoses
Internals
Extreme Arrow H- Section Rods
Steel Billet Crankshaft
Omega Ceramic-Coated Flat-Top Pistons 9.75:1 Compression
Parted Sti 4 Cylinder Heads Modified For Lobe Clearance, Fitted With Wrc/Rcms A-Ring Head Gaskets And Gas Rings
Rcms Camshafts Exhaust 270-Degree 1o.5mm Lift,Inlet 290-Degree Duration And O.5mm Lift
One-Piece Nimonic Exhaust Valves
One Piece Stainless Inlet Valves
Uprated Valvesprings
Plasma Nitrided Titanium Spring Caps
Wrc Main And Big End Bearings
Induction
Garret Gt40/88 Twin Scroll Turbo Running 2.1-Bar Boost
I.C.E. Adjustable Boost (1.2 To 2.1 Bar)
K&N Air Filter With 100mm Inlet Trumpet
Rcms High-Flow 100mm Thick Front-Mount Intercooler With Twin-Tube Core 70mm Stainless Steel Intercooler Pipework
Wizards Of Nos Direct-Port Nitrous Kit Set For 100bhp Increase
Fueling
8 X 700cc Injectors
Blueprinted Bosch 044 Fuel Pumps (200-Liter Per Pump)
Sx Fuel Regulators Set At 4-Bar Static Pressure
Goodrich Fuel Feed Pipe
Goodrich Fuel Return Pipe
Rcms Fuel Distribution Block
Fia Spec 28-Liter Rubber/Kevlar Bag Fuel Tank In Aluminum Cover
Vp120 Race Fuel
Engine Management
M800 Motec Ecu With Traction Control, Nitrous Control, Anti-Lag, Paddle Shift Control And Full Data Logging
Exhaust
Wrc Short Runner Ceramic Coated Exhaust Manifold
Tial 45 Mm External Wastegate
3.5-Inch Unsilenced Stainless Steel System With Ceramic Coated Downpipe
Drivetrain
R180 Sti Rear Axle 3.9:1 Cwp And Plated Modena Lsd Differential
Gkn Rally Driveshafts
Torque Line Carbon-Fiber Propshaft
Rcms Six-Speed Subaru Gearbox Casing Modified For Sequential Gearbox System
Six-Speed Modena Gear Kit
Subaru 3.9:1 Front Cwp
Rcms Paddle Shift System
Plated Center Differential With 1:1 Uprated Output Modena Gears
Plated Front Modena Differential
Rcms Spec Triple-Plate Os Giken Clutch And Flywheel
Rcms Hydraulic Light Pressure System
