Redlineracer12
Addicted CEG'er
Another reason why I went with a ported 3L because the 3L longblock (block, heads, cams, etc.)
There's no reason you need to use the 3L cams when you're using the 2.5 intakes
AJ is a retard. No power below 4000? My hybrid below 4000 will eat your 2.5 for lunch. If I want to drive around nicely in town, I can shift at 2k, no problem and not have to downshift all the time when I want to speed up a little. I have both stock and hybrid cars, and there is no comparison. I have plenty of power all over. SVT SNOB's straight 3L with SVT cams is awesome too.
Oh, btw the compression ratio is 11.25:1
yeah, and snob regularly says "I wish I had 04 cams, my last SVT had straight 3L, car was WAY faster"
and you are picking apart what I am saying, obviously there is power with the 3L hybrids, but a straight 3L provides much more low end power, you get similar power raitings with either 3L hybrid build, or straight 3L, however, its the way the motor actually puts the power down, besides... Why spend the extra time and money making the 2.5L heads fit on a 3L motor, when you can get a 3L, do the block modifications and throw it in the car as is and get the same amount of power as the hybrid motor, with a lower compression ratio so boost is easier to attain.
Just doesnt make sense to me, maybe someone can explain it to me better then I understand, im not saying hybrid motors are junk by any means, they require a lot of time and effort to put together properly, and make respectable numbers, but for a daily driver a straight 3L offers a much more useable power band on a daily driving basis.
2.5L heads SUCK!!! They let you keep the oil drainback problem!
ok so most drag cars that are running FI have a lower compression then that or are they running more because their running like built 302s and such??
