blu_fuz
New Member Classroom vulture
Good stuff here.
I never knew you were on these forums with me lol. All of these years, and we finally see each other on the forum rather than just the facebook groups.I thought the same thing but the major measurements all line up, its exactly the same. insane
I'm in the process of redoing all my brake lines and I'd love to go this route if you've got any info to share. Also, I love how you're quietly dropping the biggest bombshell the contour community has seen in well over a decade. Can't wait to see it finished!The front frame rails will get some extra plating when it’s cage time aswell… here’s my progress with the abs delete/ wilwood proportioning valve install….View attachment 13405View attachment 13406
That’s the link I have here to to proportioning valve from willwood at Amazon, for the lines I’m using a style of brake line that’s nickel copper, I bought a kit off eBay in 3/16 size with a boatload of fittings. I had to buy metric 3/16 fitting specifically for the master cylinder. I reused the fittings for the soft lines because the flare is different between the wilwood unit and the contoursI'm in the process of redoing all my brake lines and I'd love to go this route if you've got any info to share. Also, I love how you're quietly dropping the biggest bombshell the contour community has seen in well over a decade. Can't wait to see it
