bensenvill
you removed the caliper first, right?
:duckandcover:
:duckandcover:
:duckandcover:
Call me in 2 months when you need to replace the bearings you destroyed with that BFH.
The BEST way to remove frozen junk rotors is this:
Take a die grinder with a cut off wheel and cut completely through and down on side of the rotor until you get to the hub area. Then CAREFULLY continue to cut through the mounting "hat" are of the rotor till you get as close as you can to the wheel mounting pilot of the hub. Then take a cold chisel, insert it into the slot you cut, at the edge of the rotor and hit it a few times with a hammer (you don't have to beat the bejesus out of it) - it will crack the rotor all the way through the other side and then you can just take it off.
Saves the wheel bearings and a lot of BS in the process.
LMAO!:laugh:regardless of answer...... hahahahahahah
Now my abs lights are on .. brake sensors for the pads maybe? i didn't think i needed to replace them.. keep in mind i didnt touch the rears yet only the fronts.
