It is a ton of work and a costly bill if you are just doing it to add the flywheel. Unless you think you will be needing a new clutch anyways, and doing so at the same time, then I would say your money could be much better spent, or saved! I would put that money towards a limited slip differential before dropping it on a flywheel. The SVT flywheel is relatively light in the world of flywheels anyways.
