CSVT1214
Addicted CEG'er
P1518 is fixed!!! :shocked: Over 5 years of having the same code and it was a 15 minute fix!!
I'll be making some adjustments on Friday after I leave work, but so far, the IMRC is functioning perfectly. I bent the mounting tab for the cable up higher and the slack was gone.
The other issue I found was that the spring on my LIM was not secured in the correct spot. I had never noticed that it was supposed to be on that same mounting tab as the IMRC cable. Instead, mine had been resting on the metal fuel lines which is obviously not creating much tension on the cable.
The only reason I found that was because I compared my 98 SVT to my 00 SVT. I was using it to reference the position of the mounting tab and found the spring was secured in there as well. :blackeye:
My guess is that I didn't need to bend the tab much (if at all) and instead just clip the spring in the right spot.
