If you are on here at all, you probably know the car...
but here's a link back to some pics. . .
http://contour.org/ceg-vb/forum/gene...saga-continues
Specs/mods...
Engine:
-K&N Filter
-KKM MAF adapter*
-BAT Intake Pipe*
-Mustang GT Optimized Throttle Body*
-SHO Shop Ported Upper Intake Manifold*
-Bradness Upper Intake Manifold Spacer*
-SHO Shop Lower Intake Manifold (Secondaries Gutted)*
-Ported and Polished SVT Heads with 3L valves*
-’01 3L Shortblock*
-’05 Escape Oil Pan (revised baffles)*
-190lph Walbro Fuel Pump*
-SCT XCAL2 Tuned by LivinSVT*
-MSDS Headers*
-SHO*Shop Y Pipe
-Magnaflow Resonator*
-Bassani Catback*
-Bradness Stab-o-Shock*
-Solid Front Motor Mount*
Transmission:*
-Rebuilt and Cryo-treated by Liberty Gears
-Terry Haines Shift Tower*
-Cougar Shift Forks*
-Quaife Limited Slip Differential*
-SPEC Stage 3 Clutch*
-SPEC Lightweight Flywheel*
-GCK Axles*
Suspension:*
-KSport RR Coilovers
-BAT 21mm Rear Sway Bar
-Bradness Rear Strut Brace*
-Polyurethane Bushings*
Brakes:*
-12.2” Wilwood Front Big Brake Kit*
-11.75” TCE Rear Big Brake Kit*
-Wilwood B10 pads in front, Hawk HPS pads in rear*
-SS Brake Lines*
-ATE Super Blue Brake Fluid*
Wheels:*
-17x7 +38 Team Dynamics Pro Race 3s
-ARP extended wheel studs*
-McCann open-ended lugs*
Interior:*
-Sparco Torino Seats w/custom sliding bracket*
-Focus Door Sil Plates*
-Autometer Pro Comp Light Water Temperature and Oil Pressure Gauges
-AEM Air/Fuel Ratio Gauge*
-SVT Build # Badge and Engine Plaque in Center Console*
-Aluminum SVT pedals; Saleen dead pedal
Miscellaneous/Weight Reduction*
-SHO Shop Subframe Connectors*
-Center Seatbelt Assembly Deleted*
-Windshield Washer Reservoir Deleted*
-SVT Aluminum Battery Tie Down * (Custom One Off Smokeshow Design)
Exterior:*
-OEM Style Carbon Fiber Hood*
-Quad Projector Headlights by Pudmunkie (TSX lows, Hella 90mm highs, Audi LEDs in the bottom, Pro Burner Turns)*
I also have very rare blue Samco radiator hose kit special ordered from the UK, hasn't been installed yet but will go with the car.
Not in a rush to sell, just some things have come up. And could use some space and cash.
$4500 obo...
Specs/mods...
Engine:
-K&N Filter
-KKM MAF adapter*
-BAT Intake Pipe*
-’01 3L Shortblock*
-MSDS Headers*
-SHO*Shop Y Pipe
-Bassani Catback*
Transmission:*
-GCK Axles*
Suspension:*
Brakes:*
-SS Brake Lines*
Wheels:*
Interior:*
Exterior:*
$4500 obo...
