BAD SVT
Addicted CEG'er
Tsk tsk tsk... Noobs...
Omg. I have a 3/16" hole in the iac pipe and its idling at 1500ish rpm. It has a BRAND NEW iac... Plus now im getting a P01506, high speed input or some such for the iac? Are BWD parts just crap or what??
I had the same problem (high idle years after fixing the moosing) back when I had my tour. I found it the 3rd time I cleaned the UIM and LIMs. These vents behind the throttle body were all clogged with carbon and crap. I cleaned them out and it fixed the problem. (photo from the interwebs)
gaskets arent always in good shape even when new... I installed a set of new OEM gaskets a few years ago on my turbo car and had to change them out in 17 miles due to one leaking....
you have to torque the bolts down correctly and in the correct order also ....
This.
72-108 inch lbs for both. I always aimed for 100 inch lbs.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=v6maint&Number=931756
