doomsayer559
Replaced the engine & fuel injector harness along with the IMRC & bushings, valve cover gaskets, upper intake manifold gaskets, egr gasket, throttle body gasket, idle air control valve & gasket, pcv valve and fixed all broken hard plastic vacuum lines that were damaged due to removal. All are connected and can hear no hissing sounds anywhere. I cleaned the upper manifold with carb cleaner & a rag and scraped the tough stuff with a brush. Lower manifold also. I am now getting a P0171 & P0174 (bank 1&2 lean) + the temp raises up to 213 degrees & then the fans kick on to bring it down. The car runs great other than these few things. Im stumped. It seems like a vac leak of some sort but where? How?
