exhaust part sources
BrApple
No Life But CEG
Moderator
Gales Ferry, CT
Headers
MSDS, INC www.msdsinc.com
- short tube headers
- realistic gains 5-15hp+ depending on other modifications
Weapon-R - www.customcougars.com Discontinued
- known as MSDS knockoffs
Cat-back System
A bolt-on cat-back exhaust will result in 4-8hp depending on brand and modifications to your vehicle.
Bassani - Discontinued
- removable resonator tips to reduce sound
- loud and drones
- raspy when cold
Borla - Discontinued
SP Motorsports
www.ctamotorsports.com
www.batinc.net/contour.htm - page 33
- smooth sound similar to stock
Bosal
www.batinc.net/contour.htm - page 34
- loud with mirror finish
- flange-fit exhaust may cause some installation problems due to inability to adjust
CTA
- Magnaflow mufflers and resonators options available
- 2.5” all the way back or 2.5” -> 2.25” available
TruBendz
www.trubendz.com
- 2.5" bolt-on cat-back exhaust
- many consider best "bang for the buck" exhaust
- many muffler and resonator options available
Sources
CTAmotorsports
Trubendz
BAT
Magnaflow
Reference Material
Exhaust database- from Old Zetec Forum
Tourige Header FAQ
Tourige Header How-to
Duratec Exhaust Video Post
Since I recently got an almost new Bosal kit, I thought I'd recommend updating that section. It's supposed to be a little loud with the other stock exhaust parts, but even then, some people opt'd for the muffler "silencer" inserts.
I have headers, optimized y-pipe, and high flow Trubendz cat pipe. When I put it on, it sounded like it was just straight pipes -- wicked loud! I got the inserts and it's alot more quiet, but it's still VERY loud, and has some small rasp ranges (3500-4000; 5500-6000). I'm now planning on replacing the cat pipe with a custom pipe... using the largest muffler I can fit in that area. Though, as much as I want to make it more quiet/sane, currently 6000-7000rpm sounds very sweet.
Seriously. if you want a good sounding system, Just go Trubendz Resonated Magnaflow or Borla. Just make sure you can get it welded or fixed, because their fitment sucks arse.
For the DIY'ers
Summit, Jegs, Trubendz, JC Whitney for mandrel bends and straight pieces.
