FREE Escape LIM for oval port 3L. NO fuel rail mod/conversion required!! FREE
turbo_fox
wales ma
I bought this to use for a full oval port 3L conversion. Its from an early escape, and the fuel rail hook up doesn't use the newer returnless style connection, it also has a regulator on it. I believe, but am not 100% sure, that it can be used without having the return line hooked up, since it has a regulator on it. I also believe, but am not 100% sure you can bolt a taurus UIM to it. Basically, i bought it to try it out and see if it would work as i expected. I was going to put it onto a return style car, not hookup the return line, and see what i had for fuel pressure. I never ended up building a full 3l and this has been sitting in a box for years.
That being said, I am only looking to get shipping costs covered. SO basically it is free, i just couldnt justify throwing it away if it could be a cost saver over other options for converting return style hookups to full 3L fuel rails.
CLASSIFIEDS RULES
Last Updated: 7/20/22
