Engine swap question
briancontour24v
Hello All, I have a 2000 SVT. It has 200k miles on it. Still runs fine but I have a 1995 2.5 out of a Contour sport I yanked the engine, it only has 35k miles on it. Will it go into the SVT with no issues?
Thanks Brian
You will need to swap some pieces. The 95 is probably vacuum actuated secondary's and also the fuel delivery on the 2000 is returnless. You should be able to swap that whole intake section over to the new engine including injectors and lower intake manifold and the rest should work.
Thanks Brian
You might as well get a 3.0 to put in it. More reliable and faster. Just going backwards with the non svt 2.5 and wouod be a complete waste of time IMO.
