beyondloadedSE
Okay, heres the deal. Around normal cruising conditions at 70 mph, my EGT's have always been ~800F. However, over the last couple months, I noticed a weird exhaust note, as if there is an exhaust leak. At least that was my first inclination. However I'm now beginning to think the timing is off or part of the ignition system is bad. Whatever it is, it just doesnt sound the same. Anyways, the EGT's have also gone up as a result. At about 70 mph, the EGT's have raised to about ~900-950F. Something seems off here. Also, under full boost (16 psi) the steering wheel begins to shake when about 5,000 rpms and above. It's never done this before. Im guessing this is the engine sputtering and translating the vibration to the steering wheel. My question is, how likely is the timing to now be off? I cant see it hopping a tooth on the chain. Is it more likely its a coil pack or part of the ignition system. Could a bad coil pack/wires/plugs cause the EGT's to rise? As always, TIA!
