The old Yamaha Taurus SHO V6 engines used butterflys in the short runners that were held open with little springs. When the engine started and built some vacuum, the vacuum servos closed the butterflys against the spring force. When the ECU commanded the butterflys to open, a signal was sent to a solenoid valve that vented the vacuum servos to atmosphere, allowing them to open.
This is the logic you want on a turbo engine, but you'll want to add a vacuum reservoir in the vacuum line to the butterfly control solenoid, and put a check valve in the vacuum line from the engine intake vacuum port to the vacuum reservoir, so the butterflys will have enough stored vacuum to stay closed under light boost.
The other thing you could do is borrow the electric butterfly actuator (IMRC actuator) from the 2.5 or 3.0L Duratec V6 engine.
