ctmystique
Are both rear cables the same?
I vote for a sticky on this one as well. I am in need of doing this I just didnt know what kind of task it was. now I think I am going to jump on it this weekend.Subscribed- should be a sticky with the level of detail.
The Raybestos cables I bought were identical in every way....The cables are identical, but the springs are side-specific. The cables I bought from O'Reilly's said they were for either side, but both came with the driver's side spring, so my old spring had to be re-used. Not a big deal, though.
its called white lithium grease. can get it at any autoparts store in a spray can.
My front cable is the problem as well. Where did you find the replacement? None of my local parts stores have the front cable available.
Well, I just left the original cable in the e-brake handle, attatched a 1/8" steel cable to it via 2 cable clamps, ran it through the e-brake bracket, and held it in place with a cable stop. Then I hit everything w/ rust-oleum.
All parts from Lowes for $6.
i'd try a local junk yard or u-pull it. There are usually a few contours in them.
you can get a set of dorman cables from rockauto.com for like $30 iirc. the rear cable kit from Ford is like $50 or so iirc
yeah and the cables could be just as bad ....
(reference photo in post #16)
