Big Jim
I had a lot of experience with M85 flex fuel cars, but have had limited involvement with E85.
It is the memory of the potential problems with M85 that adversely colors the perceptions about E85.
Methanol is much more active chemically than Ethanol. M85 required a much more expensive fuel handling system. The fuel pump, lines, etc had to hold up to the aggressive nature of Methanol. E85 does not need to be nearly as robust. I would guess that those parts may even be the same as for Gasoline. Motor oil when using M85 needs to be specially formulated to handle any Methanol contamination. The M85 motor oil was a special synthetic with special additives above and beyond what is needed for normal synthetic to hold up or the bearings took a beating.
Either M85 or E85 must have a device that reads the percentage of alcohol since they are "flex fuel" vehicles, allowing the driver to fill the tank with E85 or gasoline, so that the mix could be any percentage between the two fuels.
The injectors need to be able to handle the larger flow of the E85. The device that reads the alcohol percentage, and the ability to move the tune to any variance must all be present. The fuel handling equipment must be able to handle the higher flow. The fuel handling equipment probably doesn't need much of a change.
And by the way, M85 vehicles run great with E85.
Anyway, that's what I'm aware of. I don't see how they can make all those upgrades for $50.00 a car.
