bxd20
I have an odd squeak, with pads and rotors that are only about a year old. I drive highway so the pads are still VERY thick, no cracking, no weird wear, no pulsations in the pedal, rotor is clean.
It's only coming from the driver's front brake.
Here are the symptoms. For the first few stops of the day, no noise. Then once the brakes warm up a bit, I get a squeak only as I barely touch the brake pedal, such that the pads are just grazing the rotor lightly. Push down harder, like a normal stop, noise goes away.
Or it will also happen when I'm going 5mph in a parking lot, and when I turn the steering to the right without touching the brake pedal, I get a squeak. I assume by turning the wheel, I am shifting the caliper just enough to make a little incidental contact happen between pad and rotor.
I tried sanding a bit of the pad off and a bit from the rotors, problem went away for a day and came back. Should I sand 1/8" from the pads, have the rotors turned and re-bed?
These are Morse Ceramic pads with the higher end Raybestos rotors.
