CRGkart44
Is Cruising For A Bruising
Blue.... Your Back!
ya I'am back been busy and stuff ,then when I got a chance to get on the CEG it was gone :shrug:Blue.... Your Back!
I have not checked the 7.5 amps fuse's mentioned but I will would this cause only one light to be out and why are there two fuse's:shrug:
must check then thanksOne for each side. One bad fuse = one light out
thats what I thought how do I fix it or is every body in the boat:shrug:yeah bule.... it was a sad few weeks for all of us.
BTW... your profile is EFFED. i cant PM or VM you.. and our convo is gone
must check then thanks![]()
thats what friends are foridk blue... im ok... since you have been gone i have had to talk to christine...
ok I checked all the fuse's (10 amp under hood) all are good besides if one was bad then they wouldn't work with DRL's or not .When I started this project everything was working proper. I also allready have a working fog light mod. So when I put in the relay (autozone special) and turned on the car I had working DRL's but when I turned on the highbeams only the passanger side high beam worked. Fog lights work ok lowbeams ok just no driver side high beam with DRL mod:shrug:
and both your high beams still work when DRL only?
yes both DRLs come on but when I turn on the high beams only the passanger side high beam works but all the low beams and fogs still work normaland both your high beams still work when DRL only?
found no fuse'e under dash :shrug:for headlightsI have a co-worker's that is doing the exact same thing, There should also be a couple fuses under the dash for the lights I believe.
I don't have daytime running lights on mine 99se. I have to turn the lights on to have them. What is different with yours and mine?
Does somebody have the picture of which slots I can run the jumper to disable my DRLs but still use my high beams? Looked through the thread but if it was posted I missed it. I am on mobile tho :\
