CSVT#49
Addicted CEG'er
Alright well it does require you to have a welder and some decent tools for part of it but...
Here are the details for the oil catch can that I talked about a few months ago that I said I was going to build.
x1 1/4" NPT Mini Air Filter (water separator)
x1 large camping water tight storage container
x1 pan drain plug
x1 custom stainless steel baffle stand off
x2 NPT barb fittings of your choice
x1 rubber seal and some gasket maker
x4 #4-40 machine screws, washers, and nuts
total cost = $45.10, plus some stainless steel and a bunch of labor
I ended up with this piece of awesomeness. You'll notice the blue will match my Samco Hoses perfectly. The water tight container is smoked, but transparent enough where you can see it filling up. The drain plugs on the bottom allows for quick drains as well. However if you wanted to clean the whole thing out it can be taken apart in just a few minutes and reassembled just as easily with some teflon tape.
I guess if there is enough interest I could reproduce these, but it's a lot of screwing around. Especially with the baffle piece. I think it took me about 3 hours to put this thing together after I had all the parts. However this should perform just as good as those $300 oil catch cans at 1/6-1/4 of the cost.
You'll see that I have a line installed on one end with a cap on the other. I did this so that I could pressure test it for leaks.
x1 pan drain plug
