ottawanker
So, my '95 contour with a v6 is cranking, but not starting. I've had this problem before, and it was the wiring going to the crankshaft position sensor.
I changed the sensor, and fixed up the wiring with some electrical tape near the sensor itself, and the rest of the wire that I can see (a few inches) seems to be pretty decent still. That part of the wire shouldn't be shorting out, but it still won't start.
The fuel pump comes on for a few seconds when the ignition is switched to the 'On' position. I'm currently not getting any spark when I crank. The coil seems to check out from the tests I've done, and is getting voltage, but doesn't seem to be getting signal. Also, the CEL comes on when I switch the car to 'On', but stays on when cranking, which seems to be an indicator of crankshaft position sensor problems.
I really don't want to replace the whole harness, but I was thinking about replacing (well, leaving the old ones and just running new ones really) just the 2 wires that run to the crankshaft position sensor, but the Autozone wiring diagram for '95 Contours doesn't seem to list it.
Any ideas on what my next step should be, or where that wiring goes?
