So I put everything back together after changing the valve cover gaskets, UIM gaskets and degunking everything.  It will crank but it won't turn over.  I tried using starter fluid to get it going, but to no avail.  I don't think it's getting spark, but I have to check that better today.  My guess is there is no spark because it wouldn't even fire with the starting fluid.  I know that the wiring harness is cracking under the UIM and I taped each individual wire to prevent shorting out between the wires.
What would you guys suggest I look at first?
