Contour bulb part number *sticky*
svttour
Rico Suave
MIAMI
I want to make a sticky that lists all stock bulb part numbers for the Contour from front to back.
Im going to list as many as I can please chime in with some you know of.
Exterior
Highbeam 9005
Lowbeam 9006
turn signal 1157
fog light 893
tail light 3157 for e1 1057 iirc for e0
reverse light bulb 1156
liscence plate light 3910 festoon
Interior
Foot wells 194 or 168
dome light center 3610 festoon
map lights
passenger side sunvisor mirror light
guage cluster
headlight switch 194 or 168
HVAC panel 194 or 168
center done light for late 99s and 2000s
High beams are 9005 and low beams are 9006, just so you know. Oh and also, tail lights/brake lights/turn signal in the rear should be 3157.
This list was taken from the Osram Silvania Lamp Replacement Guide
I pulled up all listed ligths for a 99 Contour. Bulb applicability does change by year in some cases. One example are the marker lights, the plug style changed.
Low beam headlamp
9006
High beam headlamp
9005
Parking light
3357A/3457A
Front turn signal
3357A/3457A
Rear turn signal
3157
Rear turn signal
1157
Tail light
3157
Tail light
1157
Stop light
3157
Stop light
1157
High mount stop light
2723
Fog/Driving light
893
License plate
6418
Back up light
1156
Front sidemarker
3357A/3457A
Glove box
168
Map light
578
Dome light
211-2
Step/Courtesy light
168
Trunk/Cargo area
6411
Under hood light
89
Instrument-general
161
Automatic transmission indicator
161
Instrument-general
161
This is not correct. It is a mistake that is in every parts store database I have seen. The gauge cluster light bulb is something called a 14V 1CP. Good luck finding a retailer in the U.S. that carries it.
Some of my backlight bulbs burned out, so I swapped them for the bulbs that are present in the IP for features that my car doesn't have (O/D lockout indicator, traction control). Problem solved.
2723
I also don't believe this is correct.
Just got some in the mail. Checked Sylvania, and Superbrightleds, and these are way smaller than my third brake light bulbs.
My third brake light bulbs are 168.
Luckily, I swapped my 168 interior bulbs, and used the old ones to fix two burnt out third brake light bulbs :D
